I just picked up a 03 LS sport rear and it needs to have some paint work done to it.  Im curious about the proper way to go about filling the words on the rear bumper.  Id hope I can use just a filler but want to make sure with people who have a bit more knowledge then me.
Thanks..
So in light of trying to awnser my own question I went searching on google and found I have a couple options.  Obviously im looking for the easiest and best.
-Using just Poly-flex
-Plastic welding them then Poly-flex
-2-part epoxy (fusor,Norton,Duramix) and then Poly-flex
2 part epoxy, followed by poly flex.
Make sure you're down to bare plastic before laying in the epoxy, and heat treat before applying the poly-flex (helps adhesion)
