i found one on ebay and i ordered it and i was woundering if anyone else has one on there car.
12.7@110MPH with 10PSI.
This is WinksOnline.com (FatalicCAVI)'s car...
-Brandon
thanks for those pics that looks even better then i thought it would.
I thought matt made his own grill.. I could eb wrong
Cool, I may use that to cover up where my got busted on some road kill.
2004 Cavalier. Razzi. (Sold)
1998 Corvette. Some mods.
1992 Typhoon. Lots of mods.
1994 Civic VX 44MPG
Wow that looks really good on that car, but not every car can pull that off.
VERY nice car bro. where you get that hood and what make is it?
it metal / fiberglass?
sharp car!
that looks like the glass rksport ss hood
Where can that grill be found? I like it
yep Ebay is were im getting mine and it should be in on the 14th or 15th so after i get the bumpers painted ill get some pics up of it on my car.
Ken wrote:I thought matt made his own grill.. I could eb wrong
What would you use to make a grill like that???
I've got one of those on my yellow 04 and it's HOT! installation was a bit of a trick..seeing as I didn't use a jack and i'm lowered 3 inches...but if you can get your hand behind your bumper ok..then it's easy..only took like 30 mins to do it right...adds a nice look the front too.
Memeber since '99
cardomain New England Tunerz
on a friend's cavi
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
Couple questions on the grill
1) Are you cutting the grill out? or placing in front?
2) How is it mounted
http://www.cardomain.com/ride/2099420/1
it mounts in front of the existing grill piece...actually *TO* it using some S shaped brackets and and some threaded bolts...it holds on real nice..what I was saying before about it being a bit of a PIA is because you have to make sure the brackets line up and grab the grill correctly and stay that way until it's tight enough to hold itself.
Memeber since '99
Code Zero wrote:I've got one of those on my yellow 04 and it's HOT! installation was a bit of a trick..seeing as I didn't use a jack and i'm lowered 3 inches...but if you can get your hand behind your bumper ok..then it's easy..only took like 30 mins to do it right...adds a nice look the front too.
do you possibly have pics of this?
Lanman31337 -F = fatties = do not want. A little chunk in the junk is ok though.
You didn't say anything to me about putting a billet grill in the new bumnpers. What's up wit dat?
Colin B. wrote:Code Zero wrote:I've got one of those on my yellow 04 and it's HOT! installation was a bit of a trick..seeing as I didn't use a jack and i'm lowered 3 inches...but if you can get your hand behind your bumper ok..then it's easy..only took like 30 mins to do it right...adds a nice look the front too.
What pics are you looking for..the brackets or the grill itself?
Memeber since '99
sorry the grill please iwould liek to see what it would look like on my yellow ls
thanks in advance
thanks i like that alot i might be ordering one now
I just ordered mine
. I cant wait to install it.
