just wondering if anyone has any tips for installing the BMX front on a 95-99 cavalier, so far it isn't bad but the area under the headlights is much to be desired.  thanks for any help.
put it on and work from the center out.  test fit it and make it work in the middle and around the lights, then use the 4 tabs in the middle between the headlights to hold it down, then just work your way around to the wheel wells.
