Make these suckers accept 00-02 lights and side markers? Right now they are 95-99 style.
Both and left sides? I have been scheming in my mind, and i was wondering whats involved? I think i remember somthing about cutting off a tab?? If someone cut paint a line and show me what has to go that would be greatly appreciated!
if im not mistaken all you do is cut that bracket off.
-Brandon
if no one else answers by the time i get back in just a second ill go check i have a 03 and they are the same as 00-02.
-Brandon
you just need to cut the bracket off. all of it. no more, no less. i did it to an old set of fenders i had.
yep this whole peice needs to come off..
-Brandon
Then i need the brackets from the 00-02+ lamps correct? Or is there a way to get the side lamp to mount to the car? I plan on going to a pick and pill and just pulling a whole new wire harness from a 00-02 cav. I am not in the mood to splice wires like crazy... will that work?
there is no bracket on the fender for the corners. yes the harness idea should work fine.
-Brandon
ya, theres no bracket on the fender for the 00-02. from what i hear there IS a bracket that bolts to the frame for the 00-02s but my girls car hasnt had that bracket for about 2 years, and we've never had a problem. i dont plan to use the bracket on my conversion either
well crap.. actually i just reread that.. ur correct there is no bracket on teh fender.. my bad..
^^^^and thats who i learned there was the rear bracket for the 00-02 corner from....
Ok i think i see how they work. As long as the side turn signals are mostly supported by the headlights i will not have a problem with them. Also, where the lamps sit on that bracket you have, i think mines a little different than the one you have. I will assume they should still sit normal since you did it without the bracket, right Eazy?
Nity9CavSedanCRJ wrote:Ok i think i see how they work. As long as the side turn signals are mostly supported by the headlights i will not have a problem with them. Also, where the lamps sit on that bracket you have, i think mines a little different than the one you have. I will assume they should still sit normal since you did it without the bracket, right Eazy?
yup, you should be fine. mine have been. cuz the turn signals clip onto the headlight bracket.
