on my 4dr sunfire for some reason my skirts on both sides are hgher in the front and lover on the back.... its like a 2 INCH DIFFERENCE. i hate the way they look does any one have any pics of a 4 door with  the streetfire front end?
Ummm...by chance do you have them on the correct sides?
Even pure genius is born out of insanity.
yea,  its says the sides on the inside of them
Ok, now that weve got the obvious out of the way lets see what else we can come up with shall we.
Just to get a little deeper into this are you saying that the side skirts taper from the front of the car bigger to smaller or what? If not then can you go into further detail of the problem so we can get you all straightened out?
Only other thing I can think of is its just the skirts you picked up. Most side skirts for 4drs have alot of taper from front to back. Why, I dont know but they just do for some reason. I know mine taper from about 2 1/2 inches in the front to about 3 1/2 in the back.
from the front its like like 3 1/2 to the back 5 1/2.. thats wut it seems like tho... im on lowering springs so its looks like my car is lower in the back and higher in   the fron, even if it werew that i cant go any locer with my front cuz im about 3-5 in away from the ground. i dunno the name of my skirts but i ordered iyt with the streetfire kit from rksports...
Ah, ok, I know those skirts. They are pretty much the same as mine and they have a big taper to them. So, yeah, the only way to even them out is to drop the front lower or even things out in the back. Or if you have the room in the back try and shim it up using a few more layers of 3m or something.
One other question that might make my help well a little more helpful. Are the skirts fiber-glass or urethane?
urathane
.... there from rksports
are they by any chances the import fighter sideskirts ?
I didnt think they made the import fighters for 4dr. Anyways, since they are urethane I same shim them bitches.
