I have a gmpp s/c, and will be switching To a t/c. My question is should I keep the reflashed ecu for a place to begin tuning, or sell it with the s/c?
Jason
USACi =>146.9db
is this ecotec or ld9? if its an ld9 you'd be stupid to sell that pcm since the 2 bar s/c flash is what you need to tune anyways. But if its an eco you're better off faking a 2.5 bar tune with hpt than hoping that the GM flash works ok in an unintended application.
Sponsored by:
Kronos Performance
It's the 2.4. I just wasn't sure, being that I have a stock ecu too, and it would make an easy sale of the s/c.
Jason
USACi =>146.9db
Get HPtuners first and download the s/c tune off the pcm and use hptuners to flash it to the stock pcm and then sell one of them with the kit.
Sponsored by:
Kronos Performance
problem with that leafy is that he would have to go to the dealer to get the stock pcm coded to his vin so the pcm and bcm can communicate and hp tuners will license it correctly.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Cant you change the vin in HPtuners? he'd just need to license the stock pcm first.
Sponsored by:
Kronos Performance
He could just license the stock ECU and flash it with the GM reflash. Only problem in doing this is sometimes it will not take correctly and cause problems.
Sounds like a good idea. Both work in my car already...so wouldn't I just copy the flash, I'm not sure I understand fully
USACi =>146.9db
Oops, another q...would I have to use a hpt credit on each pcm?
USACi =>146.9db
