My Cavalier has been long gone, but I still check out the .org a lot.
I figured I would show off some pics of my newest ride, C&C welcome!
The setup:
-JDM GSR B18C stock internals.
-Garrett .70 a/r cold/ .70 a/r hot side at 9psi
-Tial 38mm
-Hondata S300
-Dynoed 313whp
-No A/C no P/S
-JDM Type-R trans. w/ LSD (4.78 FDR)
-ACT clutch extreme, ACT flywheel
-Open wastegate dump
VTEC+Boost = Awesome!
Thanks for looking.
Damn you must burn through gears like they're going out of style. Type r tranny is waaayyy to short.
Looks good, removing the amber from your headlamps and a new grill will make a big difference in the look of the car.
i like it alot....to bad the turbo manifold is not ceramic coated or something.....would really pop in that engine bay
Rabbit(AKA RedAssassin) wrote:Damn you must burn through gears like they're going out of style. Type r tranny is waaayyy to short.
What he said
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
1st - 39mph
2nd - 60
3rd - 86
4th - 121
5th - 159
How long do you want the gears to be? They are decently spaced out with a reasonable amount of rpm drop-off during shifting.
My current gear ratios allow for speeds of:
1st - 38mph
2nd - 62
3rd - 88
4th - 114
5th - 153
Again with minimal rpm drop-off between gears and I love it!!! It's custom and it's really fun. Keeping rpms during shifts makes it feel like/sound like a little racecar. Close ratio transmissions are where its at.
I may be shortening my fifth gear (already have the gear) to 0.878. HAH! Top speed will be 135mph at 7200rpm with a 60mph cruising rpm of 3100rpm!
I like it all except for the front bumper looknig like its falling off.
How much boost you pushing through that thing?
Sweet. Always wanted a turbo civic with a fart cannon and a big wing.
Thing must fly. Any 1/4 times?
So how much do you love the S300? It's the only other platform I've tuned on besides HPT, and its LEAGUES ahead of it. Are you using the boost control feature, or the launch control? No lift shift?
I would worry about puting a filter on your turbo before a new grill.
As for the tranny if you're happy with it thats all the matters. Take a peek at the gear rations of a Type R tranny vs a GSR or LS though and you'll see what I mean.
the car has a top speed that should not be reached in that car with gears that are basically equally spaced all the way up to that top speed. That is ideal gearing in my eyes. Traction becomes the problem.
Its not about top speed. Its about the amount of shifts you take. Look at when the STI went to a 6 speed transmission over the 5 speed. They were shorter gears and it actually slowed it down. Again, it has nothing what so ever to do with top speed.
Rabbit(AKA RedAssassin) wrote:Its not about top speed. Its about the amount of shifts you take. Look at when the STI went to a 6 speed transmission over the 5 speed. They were shorter gears and it actually slowed it down. Again, it has nothing what so ever to do with top speed.
The 09/10 wrx is actuall a tenth faster to 60 than the STi but the STi is slightly faster in the 1/4.migh have something to do with the power level there.
Schaffer wrote:Sweet. Always wanted a turbo civic with a fart cannon and a big wing.
i dont see a big wing or a fart cannon, if fact i cant tell what kind of muffler is on there... anyways car looks nice, gotta love a turbo...
Schaffer wrote:Rabbit(AKA RedAssassin) wrote:Its not about top speed. Its about the amount of shifts you take. Look at when the STI went to a 6 speed transmission over the 5 speed. They were shorter gears and it actually slowed it down. Again, it has nothing what so ever to do with top speed.
I think what you meant is the 09/10 WRX is a tenth faster than the 08 STI. If thats what you meant that thats correct. Its because in 09 they got a larger turbo (41 HP more) and the fact the STI 6-speed transmission actually slows the 0-60 time down. WRX uses 5 speed sti is 6 speed.
If thats not what you meant.....then you're incorrect.
can i haz?? very nice man. not a fan of that year but def a fan of all the work into it. cept exterior wise lol fix that bumper
Thanks for the comments!
Heh, ya I like it though, as said it will still do 150mph+ in fifth which faster than I would even go in this car. But I agree this turbo is beefy and I'm sure longer gears would be better.
I should have turned the flash off for the engine bay shots, it made it look more rusty than it is.
gtpsunfire wrote:I like it all except for the front bumper looknig like its falling off.
Yea I ran into a parking curb lol and it's on 9 pounds.
oldskool wrote:So how much do you love the S300? It's the only other platform I've tuned on besides HPT, and its LEAGUES ahead of it. Are you using the boost control feature, or the launch control? No lift shift?
Its fantastic, I am using launch control and no lift shift! My check engine light acts as a shift light at 9k rpm's. I have the stock Civic tach which only reads 8k rpms.
Schaffer wrote:Thing must fly. Any 1/4 times?
I havent been to the track yet, Im thinking I could touch 12's if I could catch traction, which is kinda difficult lol
cOrpsemangler wrote:i dont see a big wing or a fart cannon, if fact i cant tell what kind of muffler is on there... anyways car looks nice, gotta love a turbo...
It does have a fart cannon haha but no wing.
Im going to get better engine shots later
cOrpsemangler wrote:Schaffer wrote:Sweet. Always wanted a turbo civic with a fart cannon and a big wing.
Not meaning this car has one. But I'd love a turbo civic such as this with a big wing and fart cannon. Just to mess with ppl.
As for the wrx/STi. I thought the 09 wrx was fast to sixty than the STi only due the gearing. If I'm wrong correct me please.
Turbo setup looks nice and all, but whats with Honda guys and the trend of making the hood as ugly as possible? Be it flat black spray primer, or rusting it out? I know the rust thing started with the euro tards, but now the Honda guys really got that ugly hood trend down to a science...
"You really need to staple your face shut"-THE Joey Baggs.
JLAudioCavalier wrote:Turbo setup looks nice and all, but whats with Honda guys and the trend of making the hood as ugly as possible? Be it flat black spray primer, or rusting it out? I know the rust thing started with the euro tards, but now the Honda guys really got that ugly hood trend down to a science...
this.
it look 10 times better if the hood was the same color as the rest of the car. it looks tacky and makes owners of cars look stupid
Its for weight reduction, flat black weighs like 47 pounds less than oem paint.
It's actually a carbon fiber hood, with really bad clearcoat!
It came on the car lol.
How hard is that to fix? Would I just wetsand, and then apply clearcoat?
Im not a great photographer, but I think these are better pics.
I do need to spend some money on the appearance of the car next.
The motor and trans, only have 55k miles,
but the body of the car is really showing its age (1997, 188k!) heh
I have an EK hatch... here is a pic of mine
Nice civic, my buddy just picked up an Si fully built and .60 trim and it's a lot of fun. Oh and that hatch is the sex
