Hey everybody ,  Anyways i am having some issue with wiring my Toyota Tail lights , I have read both DIY on this site and still no luck, i am installing them in a 2003 Cavalier , Anyways
I wired them together like the pictures show in the post here it is
http://www.j-body.org/forums/read.php?f=7&i=372909&t=372909, I have both lights wired and soldered , and i made a 2 foot
extension wire to go to the third brake light which i might be wiring it to the wrong one , I just followed the wires going from the driver side tail light , intill i found a wire loom and i cut the
white wire and spliced them together , now all that's been happening when i turn on the car is the brake lights on the driver and passenger side will stay lit up as if i am pressing the brakes, but
my third brake light is not working nor my turn signals , like i said all that happens is both tail lights stay lit up as if i am pressing the brakes , so if someone can please help me . I was out in
the rain for 3 or 4 hours trying to figure this out and still no luck.     oh yah also I did cut the white wire under the steering column also to separate the brake light and turn signals .
Bump , i Need help please
Ok i fixed it , it was of all things the fuse going to the hazard's
dude toyota probably has a site thats a forum like this one but for toyotas......
Rhen Bushnell wrote:dude toyota probably has a site thats a forum like this one but for toyotas......
You do know he has a cavy right? He's just putting the toyo lights on it.
