im lookin to get some new 19s for the ride but im jus wonderin bout them sticking out or rubbing i have 19 x 7.5 now and there firne i jus want a different lookn e help would be nice thanks
cardomain.com/id/cavilac04
you may want to talk with james (rollin19's) i think his hagens are 35mm offset,but im not sure....hope that helps!
ClassGlass / RkSport / Eibach / Motegi / Ractive / Borla / K&N
yea ill hit him up thanks
if your not on air ride you should be ok. not sure with since i have never had the same combo
I'm lowered and on 19x8 with a 35mm offset. If I hit a bump too hard my rear tires do rub, however I believe that's due to them being 235/35 and not 225/35
so then i should be good cuz ima go wit 215/35 then right
