Will a 225/50/15 drag radial tire fit a 15x6 stock 2 gen rim?
Does anybody know if thats too wide?
thanks!
Nate
1995 Cavalier W/2k1 Engine
I dont think so... I have 225 on my 7" rims... Judging by that... id say no... but im no expert
they should fit, but I wouldn't reccomend it unless the manufacturer says it will fit. Call them up, or ask your local tireshop. Tire manufactures typically post rim range, of how wide or thin it can be.
-Chris
According to TireRack, they'll fit on wheels from 6" to 8" wide.
Keep in mind though that those tires are an inch shorter than the stock tire height so they'll look funny and cause a number of issues for your car. If you want wider tires, go with a 225/55/15 instead.
Well going from his double post about it, he is using drag radials, they will be fine.
C24NA wrote:Hey guys,
Ok. I've narrowed down what drag radial I want. It comes down to BG's, Nitto N01's, or Yokahama A032R's or A048's. BUT.. i'm using a 2 gen rim, 15x6. And the tires come in 225/50/15 and i don't know if that will fit the 15x6 rim.
Anybody have any comments on tires to use or size?
Thanks
Nate
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Wild Weasel wrote:According to TireRack, they'll fit on wheels from 6" to 8" wide.
Went to the tire place. Yes, 225/50/15 will fit a 6-8" rim..like u said. BUT i would go to 55 series b/c of 1" diff in height, but i can't. They don't make them that size
Nate
If they're for the track, then the 50's will be just peachy. If you intend to use them for street driving though... then I'd look into a different brand of tire where you can get the correct size.
