I have 1993 cav vl 2.2 with 4L60E stamped on the transmission oil pan. Will shiftplus work on this configuration? I already tryed installing as per instructions both B&M's and on the org. with no results. B&M says not designed for front drive at all ie: no help. I do not have the plug at the front of the trans like the 40 does.
Any help out there would be greatly appreciated.
I would think having a RWD cavy you'd already have this stuff figured out after all the work you already did.
www.gmscf.com
??????????RWD cavy?????????
its FWD
Hooked up at computer to red w/ black stripe and blue w/ white stripe
Soldered connections
HELP PLease
Any help out there?? Any?????????
I would really like to get this working.
Do not have plug on front of trans.
Have small grey connector with two wires.
Thanks in advance.
In either case I don't think it will help him. Cuz I can think of 4 transmissions.
1 - The TH125 which is 3spd, hydraulically controlled.
2 - The 440t4 (don't think it was ever in the Cav though)
3 - The 4T60 Similar to the 440T4, yet not electronic. Transitional to the new 4T60E
4 - The 4T60E, which is only partially electronic. If I remember correctly it's only electronically shifted, yet pressure control is still run by a vacuum modulator, which means that the B&M won't work for it.
www.gmscf.com
Thanks everyone for the insight.
Shifter is 1 2 D.
Overdrive is auto in D.
Oh yeah,
I can't find a modulator or the round plug on trans.
I have been over and under this thing several times.
I know 93 was a transition year but thought the trans would stay same.
Thanks again for the help.
r vogel wrote:Thanks everyone for the insight.
Shifter is 1 2 D.
no, torque converter lockup is automatic in d. you dont have an overdrive trans. the shiftplus will not work on your vacuum controlled non electronic transmission.
Thank you everyone.
I'm a dumass!
Anyone want to buy a Shift Plus??
