isuzu m/t drain and fill plugs? - Transmission Forum
Thursday, December 14, 2006 4:14 PM
does any one know where the drain and fill pugs are on a 98 cav m/t 2.2ohv
Re: isuzu m/t drain and fill plugs?
Thursday, December 14, 2006 4:54 PM
well, if you look at the bottom of the treans from behind the front rotor (i reccomend taking off the tire) you realy cant miss the drain plug. as fot filling, once you have said wheel off, you'll see a little thing above the plug what looks like a lever. if yours has anywhere near 100k mi. on it, it might not be white anymore, but thats what color its supposed to be. if you can, BEFORE lifting that latch blow the direct area off w/ shop air so you dont get any dirt in your trans. then lift and remove the plug, clean it off, and refill wit the car on a completely level surface. make sure to have at least three quarts of synchromesh on hand. to fill, i find the easiest way is to run a clean piece of 3/8 fuel line down from the top of the engine compartment, one end in the fill hole, and place the tip of the bottle in the other end, and fill away.
Friday, December 15, 2006 4:32 PM
thanks a lot i've been trying to find out that for the longest time
Sunday, December 24, 2006 12:06 PM
hey i found the drain plug but i couldn't find the fill plug. i didn't see any lever of any kind except the shift linkage.
Sunday, December 24, 2006 1:01 PM
There should be a big white handleish looking thing on the back of the tranny, thats the fill hole and dipstick.
Sunday, December 24, 2006 1:09 PM
to add on to that... here's a pic... its on the firewall side of the tranny
Monday, December 25, 2006 5:45 AM
Kardain wrote:to add on to that... here's a pic... its on the firewall side of the tranny
Non premium members can't see attachments...
Wednesday, December 27, 2006 1:28 PM
dude your a life saver thnanks so much, if you lived in pittsburgh i'd buy you a beer or 3
