i just got my turbo and was wondering which size pipes r normally used 2.25 r 2.5 thanks for the feed back
couple of different factors can influence your decision. one would be what size turbo you have? another would be what power gains are you looking for? Think of it this way....the smaller diameter piping will allow quicker spool up because you will be filling less of a space w/ compressed air....but the bigger diameter piping allows more cfm to flow if you have the turbo for it.
***Need an '02 or up Cavalier shell...stock prefered...email me and make an offer***
i plan on changing my piping over the winter, most of your turbos have a 2" compressor, so im going to run 2" pre intercooler and 2.5 after to the tb
off topic but josh looks like you plan on making a return to a cav.
so 2.25 will make the turbo spool faster
are you going to sell your old piping brandon?
yes, the 2.25" piping will make the turbo spool quicker. 2.25" should be fine for you.
Boosted2Point4: looks that way, huh?
it's best to try and buy an intercooler that has your desired pipe diameter end tanks as well. For example, an intercooler that has those 2.25 or 2.5 inch end tanks as opposed to say a 3" so you don't have to do a bunch of crazy @!#$ with it. But yes 2.25 or 2.5 is ideal
ok thanks i think ill go with the 2.5 a little more air
it also depends on how much boost your running. people usually run smaller pipe before the intercooler and larger after. I am running 2.5 with no probs, incase you decide to upgrade the turbo,turn the boost up or do more mods just go with the 2.5
cavaliers been laid to rest
The saturn is being born
a new cavalier is in the mist
im only going to run 5lbs of boost for now till i get fuel upgraded
well see when you upgrade fuel i am sure your gonna run more boost. i run 8psi all day in my saturn with 2.5 pipe and i have no leg or anything and its a t3
do u have any pics of your turbo set up
its a saturn but i don't know how much it is going to help i have more but haven't uploaded them yet, heres my car domain
http://www.cardomain.com/ride/843404
