Hey guys, as I have been doing some more research on my turbo project, I have come across two types of turbo wastegates, internal and external. Which one is better? I would like for the wastegate that I get to be adjustable from inside the car. So what are the pros and cons to both? Thanks, Paul Moore
Trying to become the most modded out N/A 2nd gen sunbird 4 cylinder on the org with a..... screw that, I'm going turbo!!!
2.Slow OHC I4
Ported cylinder head, intake and exhaust
Relocated IAT with a custom WAI with a 6x9 K&N conical filter
All this, and I still can't go fast.............yet!!
Well, speaking from first hand experience, I would have to say that External is the best way to go.
Internal is not bad, but sometimes it is harder to control the boost and sometimes I would get boost spikes.
With external, I have found that it is a bit easier to control boost levels being that it is a bit more accurate.
As far as controlling boost levels from inside the car, you are going to need and electronic boost controller OR Trubo XS has a dual stage unit that can be changed from low to high boost with a press of a button, but the 2 stages of boost has to be changed under the hood first then you just use the button to change between the 2 set levels.
Either wastegate that you decide on will work with any boost controller and you can control boost levels from inside the vehicle with a electronic boost controller if that is what you want.
Internal is still not a bad option if you decide to go that way, but I am a fan of external ever since I went with a new manifold setup with a external wastegate.
I also use a Greddy Profec B Spec II Electronic boost controller on my setup and I would not use anything different. Very easy to use and can change from high to low boost with one button press and boost can be adjusted with just a turn of a knob.
Hope that helps some.
Later,
Jeff
2000 Turbocharged Silver Z24 5spd
Cardomain Site
also internals usaly have a problem with heat
Kick azz is my boost hero!!!
Not to mention they love to creep..
z24 aint afraid of no ecotec
We use to use internal for our kits and recently switched to external. I prefer the external MUCH better...
MaximumBoost.net
1-888-TURBO-31
sales@maximumboost.net
TAX ID: 45-8013458577-3
Thanks for the input, external it is!!
2.Slow OHC I4
