Well Actually it is done but I'll mention the one problem I'm having at the end...
Had to relocate the cruise control bracket slightly for added length for the cable, for the new throttle body position.
The inlet pressure sensor location on the ion is a perfect spot for your stock GM Map sensor. Even the bracket to hold the sensor fits on the map sensor, although you do have to extend the wiring.
And yes the hood closes
Now onto the current problem. I had the car running and all was well. I had not driven it but it idled and ran smoothly, all was well. While I was adding coolant I had the car running for about 10 mins trying to get it to circulate. I started hearing a ticking noise which happened to be one of the ribs on the drive belt comming loose. Well I did notice some small damage to the belt before putting it on. I let it run to see how badly it would affect the belt and it shredded itself all at once.
The cause/problem is that everything on the Ion enging uses a 5 rib pulley. I used all the parts I could including the ion alternator. So my A/C compressor and Crank pulley are 4 rib pulleys, so they are cutting the belt. I would assume that the GM S/C kit belt is a 4 rib version of this belt but I doubt I can order it. Autozone and murrays cannot get these belts either because it is a dual sided belt.
So I either have to use the crank pulley off the redline (no big deal) but also manage to change a/c compressor or just use the clutch/puelly off the redline engine or find a 4 rib belt. I don't have the A/C pump so I'd rather get the 4 rib belt.
In any event that's the only thing holding me up....
Things left to install are:
Later once it's up and running I'll make it intercooled... water pump has been ordered (one on the engine I bought was damamged).
The belt may be a setback... I was hoping to have all this done wednesday but I'm not sure just yet.
so you're rockin the freakin comanche? lol
you shoulda asked , i coulda told you the belt on the s/c motors had a extra rib
looks freakin sweet man
just get the stock belt and cut a rib off it
i love it.
awesome work. keep us updated and good luck
Use the ion crank pulley and loose the A/C, might change belt length though.
flippin sweet man! Hope ya can get the belt issue worked out...and happy boosting!
Looks great Jon, glad to see it is all coming together nicely. I can't wait to see it done, this will for sure help your autocross times buddy.
@!#$ sweet!
Find me a 2.0 S/C engine for cheap
omg.. that is sooo sexy! how hard was it to make the adapter plate for the tb? did you make it or did someone else? cant wait to see the hp you put down with that thing.
So thats the 2.0L engine? If so did you order that straight from GM?
Looks real good, congrats on the near completion.
the engine is used if im not mistaken, out of a redline. now i have to go scouring through junk yards!
Good job.
Get that thing to a dyno when the problems are fixed. I would love to see some numbers. I assume since you don't have the boost gauge in you don't know how much boost you are seeing correct?
hes got a boost gauge just didnt install it yet, of course hes not going to go run blind boost
208whp 239wtq
13.7 @ 102mph 2.19 60'
wow that is just amazing... i hate you though... i wish i could intercool my supercharger....very well done....
I got one word for everything ...... "DAMN".......
about the s/c and about the problem..............
Sweet waiting for times......
haha
JDM Civic Hatch
I gotta question for you.....AS soon as GM releases the 2.2 charger...im going to be getting it....BUT i do have a carbon fiber invader hood so im worried about it hitting the charger. How much room do u have between the Charger and the hood? Any IdeaS?
I gotta say man that is friggin awesome.
Really nice work, with the intercooler and e-manage you should get much better results than the factory s/c ecotec upgrade that some are waiting for.
You make me proud Jon.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
about time someone gets some balls and runs a bigger blower unit! thats great keep it coming!
Airtonics, the stock belt in the 2.4L GM SC is a 10 ribs 1851mm (72.87") (4100729 - 10PK1851) long belt cuted by half, then is a custom 5 rib belt.
If you can't find the belt you are needing, try to measure it and go to the Gates belts catalog. There you can find a giant pdf archive with an interchange belt database by long and ribs. It is really useful. Also you can use the online interchange database to find it in other brands, like Goodyear Gatorback.
I hope this info help you.
Regards,
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
now that is some nice stuff
Eliot, the redline has a two sided belt so autozone/murrayrs or any other place won't carry it.
I purchased a new belt and carefully cut a rib off of it. It seems to be working out very nicetly thus far.
So everything should go as planned, emanage will be installed tomorrow
Oh and S/C whine sounds pretty good
Jon,
there are double sided gatorback belts. might want to look into a 4-rib one if possible.
Also, you didn't tell everyone who's uber supreme and found your pot o gold for ya
See you in 8 hours. Countdown to Ecotec bliss.....
