Anyone know what it is? Super 16g Stage II Kit
8-10 PSI typically.
We also have 5 PSI and 15 PSI versions available, but only in our Modular series that feature replaceable springs like external wastegates.
Did you need some tips on working with one of our Stage II actuators?
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
Well I'm curently running about 6.7 psi of boost, I purchased an AEM Tru-Boost Controller to up my boost to 10 psi and was just trying to get it set up where I needed to be.
That controller should work to get it to 10 PSI. Let me know if you need any assistance.
Bill Hahn Jr.
Hahn RaceCraft
www.turbosystem.com
Thanks Bill I'll let you know
I personally have the Greddy profec B spec 2
I likes it, works great.
AEM is good unit too.
I got a great deal on the tru boost plus I have aem's wideband and want to keep them all the same
Can someone tell me which way it goes? The higher tension spring would be higher boost or lower boost vs. Lower tension spring? I have a generic wastegate
USACi =>146.9db
