i purchased a cometic head gasket for my eco and its been around 2-3 months and its taken a @!#$ on me at only 13-15psi, im know just finding out there garbage...
my question is wouls i be better off with a stock L61 gasket or an LSJ one???? prolly the lsj correct
Built&Boosted moar
did you use ARP studs??? the gasket should never blow out. did you reuse your head studs when you installed the gasket??
ge_forcez22 wrote:did you use ARP studs??? the gasket should never blow out. did you reuse your head studs when you installed the gasket??
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Luke Heier wrote:ge_forcez22 wrote:did you use ARP studs??? the gasket should never blow out. did you reuse your head studs when you installed the gasket??
No i did not reuse my head bolts..but yes i used arp head studs..
Built&Boosted moar
how did you clean you head to prep it to install the new gasket??
the block was decked and the head was machined and P&P'd and was flowbenced..they said that the gaskey had a distirtion in it???wtf
Built&Boosted moar
The MLS gaskets all require a specific rms surface finish on the head and the block in order to seal properly, I believe it 60rms or 30 rms or better I forget. I have them in my supercharged 383 and they work great and I plan on using one on my current turbo buildup.
2000 Z24 5spd header & catback for now.
