I have an 02 ecotec an was wondering if anyone has an suggestions on where to get an turbo. I have found a couple but they are for manuals. the problem is i have an auto. The site said i could still use the manual if i tweaked the pipes a little bit. would that work? the site is www.sportcompactonly.com
Either custom for a automatic or a gm superchager is the way to go. pretty much those are your options becuase of the auto.
We are in the procress of designing a kit for your engine/trans setup.
www.hrprowelding.com
^^^^^ Beautiful manifolds.
I did an install on NJHK's auto ecotec using a pieced-together kit which is what most people do. There are a lot of turbo auto ecotecs on the site.
Cardomain|
Myspace
Check out my registry for ideas.
You can also make a log manifold fit if its built with your auto trans in mind and as long as the turbo flange is more towards the drivers side of the engine than the passenger side. There is more room over there, especially if you are planning on keeping your A/C. Drawbacks to putting it closer to the Drivers side is the amount of space between the turbo and the coolant hoses / fuel lines. Both of which can be re-routed to protect from melting.
It's tight back there, but can be done. Hope you have skinny hands! It helps!!
Check out my Part Out List!! Great Prices !!
http://www.j-body.org/classifieds/detail/52925/
M I N I O N - Sinbird wrote:^^^^^ Beautiful manifolds.
Too bad i'm still waiting on mine....
