well i think its with the tranny, its pretty weird
ever since i installed the pulley boys quick change pulley system i have heard this sound coming from my car
when it is cold and i put it into drive i hear almost a metalic tick, its not real lous but loud enough to hear, almost like you are hitting a metal rod on something
but it only happens when i shift from park to shift
anyone else experince this!?
wow your tranny is boosted? how'd you do that?
typically if you heard that type of sound on a rwd car, you could bet on the u-joints being bad... perhaps you have an axle with a torn boot and no grease that is starting to wear out?
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
I'll have to hear it brian. From what your saying it almost sounds like the same sound I was getting when I had the interceptor in my car. If it is its just the trans going into gear making that noise from the extra pressure.
I have experienced this too... i had the b&m shift plus kit . . . . and when it was set to hard the noise was pretty loud... now i control shift pressure with hptuners, and it makes the same noise... i think its normal... it didnt make the noise when i floored it with the b&m shift plus . . . so i assumed it was shifting with the same strength no matter how hard i was pushing the car.... with hptuners you can set the shift pressured dependant on how hard you are pushing the car
