anyone know of anything bigger than the gm s/c? or something to beef it up at least?
you can custom fab or modify the manifold to fit a larger eaton charger. the ld9 kit come with a m45 and the eco kit comes with a m62. u can modify a m90 to work off a gtp
Its gonna take some work to do it on a 2.4, because you either need to be crafty and find a way to remote-mount the blower, or fab a manifold for it as well. Somebody was working on an M62 kit for the 2.4, but who knows if it'll ever see daylight. I've seen pics from someone on Quad4forums that did some fab work to mount a bigger blower, not sure if it was a 62 or a 90. Either way, if you can't weld, or can't afford to pay someone to fab it for you, you may want to go another direction.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
a guy had an m62 on his 2.4 with full msd.. it was a black z24 with a body kit cant remember his name he posted pics a LONG time ago even before the gmsc kit was out I believe or maybe shortly after... it was sick..
zzperformance.net can port your m45 and stuff m62 internals inside of it as well as m62 with m90 internals and so on... check it out
LE61T PTE6262 Powered
QBE (The Boosted One) wrote:zzperformance.net can port your m45 and stuff m62 internals inside of it as well as m62 with m90 internals and so on... check it out
Where on their site does it say that?
you cant put M90 internals into a M62 case , the M90 rotors are about twice the size of the M62
the only thing they share is the rotors are the sma length
the M45 and M62 share the same rotor diameter , but the rotor lengths are different
i believe farmer??? was it that had a m90 on his cavi?
i think farmer had the M62 from a 3800. its on ebay as we speek.
FarmerZ24 had an M62 on his 2.4, hole cut in the hood to fit, kit's now on ebay. The other guy's name was Marc Anthony I believe, I have the pics of his setup on my computer at home somewhere, very nice, not sure that it ever ran though.
[quote=97cavie24ls(JDM&00s/c sedans™)]you cant put M90 internals into a M62 case , the M90 rotors are about twice the size of the M62
Exactly. I just spoke with the owner of ZZPerformance, and they said they don't work with M45's at all.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Ian Brydon wrote:The other guy's name was Marc Anthony I believe, I have the pics of his setup on my computer at home somewhere, very nice, not sure that it ever ran though.
Correct, and correct again, it to this day still hasn't run.
14.330 @ 96.37mph
yeah the guy I was speaking of didnt have a hole cut in his hood..
damned I coulda sword I read somewhere they could Port it out (the sc case) and in some cases stuff different internals in....
