Hi Guys
I just want to know where did you buy your turbo at and how much did it cost you for it because i am looking for one right for my current setup.
Opening Soon Kustom J's
www.blaastperformance.com round 600 shipped cdn with a internal gate and gaskets
maybe try
www.westcoast-turbo.com
or down2turbo on ebay, those are the cheapest two places that I have seen
is westcoast turbos is a good place to get a turbo?
Road Race Engineering (Mitsubishi OE turbos from Japan).
Opfer benotigt. Keine Erfahrung notwendig.
Victims needed. No experience necessary.
Ya both down2turbo off of ebay are awesome as well as westcoast-turbo.com. They are both well to work with and both the cheapest I have seen.
I go straight through Turbonetics...
P&P Tuning
420.5whp / 359.8wtq
it all depends on how good of a rebuild, if its all new parts put in it, there shouldnt be a problem, lots of peeps seem to like rebuilt turbos
x2................
Mine was a rebuild Direct from Garrett.......... every piece was new except the exhaust housing............ my hot side oil seal blew...... so this is how I know that the stuff was new....
(I rebuilt it with a licensed mechanic)...................
rebuilds are fine ...... just not xs power or anything of that cheap nature..... hell there are X amount of people running only 300zx t3 turbos with no problem................ it's all in how you treat it too.........
Lee
JDM Civic Hatch
Westcoast is great when they're not busy. They're still trying to catch up on their blow out sale they did this past December. I would recommend down2turbo on eBay. He can get you anything you want without risk of getting a crappy Chinese turbocharger.
I just bought a T3/T04E from down2turbo for about $30 less than Westcoast. Here are the specs:
T3/T04E
57 trim
.50 a/r compressor housing
.48 turbine housing
stage I T3 turbine wheel
360 degree thrust bearing
Mind you, Westcoast doesn't sell turbochargers with a 360 bearing without you having to ask for it. Even so, the bearing normally costs between $100-$130!! So overall, I paid about $160 less going through down2turbo.
I will NEVER change my sig. HTML 4 EVA!!
how can i search down2turbo on ebay?
Search by seller
ok thanks mr.pute so what size do you think i should get for my 3400?
Off an EVO owner who was trying to sell it on an SRT Forum lol
