Greetings ,
I have a 2000 Sunfire with a 2.4 that I am in the process of swapping an L61 (2.2 Ecotec) from a 2004 Cavalier . Both are auto (4T40E), (MN4)  transmissions.
I have read the swap guide and am very comfortable doing the swap , only question that I have and have not been able to verify with the search feature is that the Cavalier does not have ABS or traction control option whereas the Sunfire has these options .
If I use the engine harness and ECM from the L61 in the cavalier and plug it in to the Sunfire at C100 under the brake booster , do the passlock relearn , what will happen with the traction control and ABS system on the Sunfire ? Will I have ABS light or T/C light on ? Will the transmission still shift properly ? Any other systems affected?
The Sunfire is basically a loaded model , whereas the Cavalier is a stripped daily driver.
Any help will be appreciated , I thank you in advance.
TOM
you will need the full harness
you wont have abs but you will have traction control but you wont have abs you will need to find a harness for a car with both auto and abs
JBO since July 30, 2001
Thanks for the replys,
So if I use the harness I have , I will have no ABS .
Other than not having it , which is not a problem for me, are there any other drawbacks ? I was planning on swapping the Master cylinder and brake valve by the master cylinder from the Cavalier to the Sunfire to eliminate the ABS anyway.
I didn't know the traction control would still function , that is good to know .
Hope this all goes well , engine is out and the Ecotec is all but ready to go in
Thanks again
TOM
