I googled around and found one reference that gave a Quad 4 long block as weighing 184 lbs.  (This from the Quad 4 forums.)  The 2.4 TC should be similar.
markc50...formerly 1of7627 but that login doesn't work anymore.
I would assume less than 200 since I can carry a long block...or at least set it into a truck bed or j-body trunk.
I am looking more for a complete weight minus alt clutch etc.
I did see the 185 for the 2.3 long block, but finding different numbers ranging from 270 to 284
plus with the ld9 i would think there would be more weight due to balance shafts etc
http://quad4rods.com/index.php?Itemid=39&id=21&layout=blog&option=com_content&view=category
What does a Quad 4 weigh?
325 Lbs for an engine with clutch, flywheel, starter, alternator, water pump, intake and exhaust manifolds and coil pack.
http://texaslocost.homestead.com/Quad4page.html
I finely got a chance to weigh the engine and parts.
The basic engine, all assembled..........................................241 lbs
Flywheel..................................................................................15.4 lbs
Clutch..........................................................................................15 lbs
Bell Housing...............................................................................13 lbs
Intake Manifold.....................................................................8.8 lbs
Exhaust Manifold.....................................................................7.6 lbs
Alternator..............................................................................10.8 lbs
Starter................................................................................  ....14 lbs
for the LX9 i have
http://60degreev6.com/forum/showthread.php/41003-Official-LX9-Weigh-in?highlight=lx9+weigh+in
Official LX9 Weigh in
    340lbs on the nose as pictured for a 3500 minus the alt, P/S and A/C.
http://www.weatherallsautomotive.com http://www.planethax.com/j-body
id love to know, myself.
only thing i have to add is the LD9 block is definitely heavier than a quad 4's. its not only got thicker cylinder walls but also a more substantial crank main webbing area.
ive personally lifted an LD9 block, then a 94 quad 4 block, then a olds rocket parts quad 4 block. the LD9 block definitely was the heavier out of the two while the olds rocket block was extremely light. im gonna say 20-30 pounds lighter, honestly.
also, to add...   the LD9 may have balance shafts but its also got smaller and lighter everything versus a quad. smaller pistons, rods, lighter crank by about 6 pounds, the entire valvetrain assembly is smaller/lighter and also has a lightweight plastic composite intake manifold compared to a quad's cast aluminum manifold.   but, as i said.. the LD9 block felt heavier to me. id say in the end, both the quad and the LD9 are within a few pounds of each other.
Come join us over on the Olds Quad 4 and Twin Cam Facebook group!
Brad I'm disappointed you do not have these wieghts written down. Right now you must go out and get them!! Hurry now we are waiting.
