LD9 Metal Coolant Housing Yet?! - Third Generation Forum
These engines have been out so long. Does anyone know where to locate a metal housing for this engine yet? I cant seem to find one other than to do a RWD setup in a hot rod. I beloieve that also changes the hose connection so it faces upward.
Any help appreciated. All links I found siompy mention "ya, its plastic, repace it" Lets face it; we all should know that by now
ive heard of people modifying the Quad4 housing but i have no pics. But honestly, if you clean the outlet port and NOT slather it with RTV (like so many i see setting in yard) you hardly ever have an issue.
working on GM's for 12 yrs; i've seen what you're talking about firsthand. Was just going to put the new one in, but i figured if i could better prevent a future reoccurence.....
88-89 LG0 Thermostat housing.  If I recall correctly. i needs one blind hole drilled If I recall correctly.  It has been a VERY long time since I messed with it.
Anyone have a how-to on this before I order one? Looks different(which we already knew), but was curious if I needed a hose barb or anything to make it work.
No how to.  There was a thread where a guy was trying to do this but never finished.  I have no idea what the name of the thread was to search for though.  I do know this it did need modifications.
Ill bet mark at OEM can make them.....
man, i cant believe more havent been made.
I could easily design one also.
well, maybe we should see who is interested in one. Are you interested in a production run? How much would we be talking price-wise? Maybe PM me.....
Zs Z wrote:No how to.  There was a thread where a guy was trying to do this but never finished.  I have no idea what the name of the thread was to search for though.  I do know this it did need modifications.
I know who your talking about. Lol
Ill have it finished this weekend. As mike said there is a hole that needs to be tapped and plugged and a hole cross drilled. Shouldn't take much time.
Im interested in one if the 95 Ld2 and the Ld9's are the same....
I believe ion had an aluminum one made. It would be easy with the proper tools. I just done have a tight yet. Soon though.
I happened to glance at an old 2.5L. It too has the "t-stat" housing on the left side. I wonder if that could be made to fit...? It is metal and not plastic.
DSM-looking to finish my engine, so if you have any info or pics you  could share that would be appreciated. I know I can get 2.3 housings. PM me if its easier and I'll send you an email addy.
I did finish mine friday. Here are a couple pictures.
doesnt look tough at all. I just didnt have one in front of me to compare. I'll pick one up and get right on it.
THANKS!
Good luck with the rest of the build. I saw the bearings in your other post.
Was I correct in remembering the model year of the metal housing?
Pretty much all the 2.3s had the metal housing. I bought one for a 93 grand am which is what I use when ever I order 2.3 parts.
94-95 quads ahd the plastic one too, came with the bottom mount thermostat.
Spencer wrote:94-95 quads ahd the plastic one too, came with the bottom mount thermostat.
x2
Im pretty sure the 95 in my shed has the plastic one.
It may also depend on what car the motor was in. It would make sense if the 95 js. Had the plastic as the angle on the aluminum one is slightly different
yes 95 has plastic, well bakolite..spell?  either way, def want a metal one, thinking a closer look is in order for me as well.....fieldtrip!!!
I recently saw a ver nice metal on. I think only 2 were made, and made for a LD9.
