does anyone know if they make a pigtail for this connector i have a problem right where the wires go into the connector . my lights randomly shut off and turn on as well as the radio  horn and ac . i narrowed it down to the connector i  just cant figure out which wire it is
if you narrowed it down to that connector you have BIGGER ISSUES. the C100 harness ONLY does mechanical its basicly is a connection point for the Engine fuses that are inside the drivers door insted of engine bay fuse panel aswell to connect the fuel tank and evap stuff to the front of the car
your headlights and other lighting and radio DON'T GO INTO THE C100 better start looking again
JBO since July 30, 2001
Check the ground under the battery tray, it is a known issue with 3 rd gens.
