Wondering were people were puting there ground wires on the ecotec motors? Pictures would be a great help thanks in advance.....
that website doesnt show me were to ground from my engine to the body....has anyone done this please let me know...
On my car there are several grounds to the firewall...
 The best places are the stock locations.  With the exception, connect 1 to the back of alternator bracket and run 1 into passenger compartment and connect to ur steering column bolt. That way for future interior add-ons you can connect all grounds there.
  I connected from battery to battery base point, where I put the multi connector:
 1 to the ground below the head.
 1 to the alternator bracket
 1 to the interior steering column
and anywhere else you see a ground point.  Even firewalls.
I have anodized points, but no good connection so I had to sand away the anodize.
I recommend this strongly: In other car I had, I blew up my 300 dollar TACH,  Killed the ECM, and stalled out on the freeway.
This time I opted for the Optima battery with top and side mount.  Kept stock ground cable, but added top negative to the central ground connector(multi).
I hope this helps.
