i have been having this issue with my car not starting
i have full power when i go to crank it but it just wont even engage the starter to turn over
i was wondering if this was a common prob cause it starts when it damn well feels like it!
sometimes it starts and i will shut it off and then two seconds later i try to start it again and it wont do anything
and advice would be helpfull
oh and the car is an 01 cav 2.2l with 34K on it
so pretty annoying considering
check your battery connections and the connections at the starter.  if those are good have your starter tested a few times, it may be going out.
-Chris
its the starter or more likely the starter solenoid
check igition switch, IE make sure hot in purple solenoid wire when in crank position
if so then the solenoid is shot
new solenoid
not the starter
unless the solenoid makes a single and strong click every single time you put the key into the crank position
if not then solenoid or ignition switch
check wires first though, al of them, make sure all are tight clean and dry and not corroded
it doesnt take much corrosion to mess things up
at all
-96 cavalier 2.2 auto 143k miles
Ok So i cleaned all the wires up and reconnected them
it started for the first time in a week and then i shut it off
went to start it again and nothing then i went to see if i left somting loose shut the hood
then went to start it and vroom vroom it starts up
