hey everyone, im new here so welcome me or whatever, but check it out, my head gasket blew so i decided it was time to start some (more than bolt on) modifications, im gonna have it ported and polished, my question is, does anyone know of a performane camshaft for my engine? its a 94 2.0 n/a OHC....
THANX in advance...
mantapart is the only one i know of
There are cams from mild to wild available from;
Kent Cams
Piper
Cat Cams
Shrick
Lexmaul
Dbilas
But........they're all from europe
You could contact Rob on Migweb here
Rob at RSC He should be able to sort out a decent spec Cat Cam and help with shipping to the states.
Stef
ps the fancy steel rods shown in Robs thread for the XE will also fit the OHC if the pistons are modified to suit a full floating pin ie circlip grooves machined in.
LT3 Powered Vauxhall Astra.
Intercooler, Mopar Super 60 Injectors, SDS Stand Alone EFI, Ported Big Valve Head, Cast T3 Manifold With External Wastegate + More
I got a whole bunch of valvetrain parts for mine last year, take a look...
Stef
dude, if you could help me, i need a good cam for my car, and some other things, its a 2.0L OHC sunbird (1989)thanks
"Hondas are like tampons, every pussy has one!!!"
www.coltcams.com
watch for flying sparks!!!
alright, thanks man, tooks like they got alot, and they custom make?  know naywhere for bigger valves, valve springs, retainers, cam followers, and lifters as well? thanks
I need more performance from my Sunbird too. I plan on a teardown and rebuild in the spring some time.
yea, go to my myspace, www.myspace.com/bullet_2005 and my latest blog is there if u wanna know what all im doin or check out my car domain... it have some good pics of my teardown... its
http://www.cardomain.com/ride/2428046   what parts you need? i can prolly get u some of them
Mine is a turbo Sunbird, and I have a slightly bigger turbo and am running more boost than stock. It's running fine, but I want to freshen the engine up a little and get more power.
mantapart makes a good cam but they are a real bear to deal with. 2.0 motors respond very well to head work, esp. p&p jobs as the heads on these motors are sssoooo restrictive. so much material that could be taken outta there lol
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
What all can you do to the head on these motors for more HP? I already know im doing a port and polish, 3 angle valve job, and getting oversize valves, do you know of anything else that would give a gain? thanks
