help fuel block seal - First Generation Forum
Saturday, September 29, 2012 8:18 PM
Amyone know of a source to get a fuel block seal for the 2.8.
its the seal under the schrader valve block
Re: help fuel block seal
Tuesday, October 02, 2012 7:26 PM
Ron Love Online
Question you mean the fuel block OR is it really the fuel pressure regulator which is what I interpret that as? IF so you can not just replace the seal on the FPR it has to be bought as a whole part.I did some checking using some dummy specs like 87 year and I know the eng.The only thing avail is the above,or like gaskets for the fuel rail (orings and such).If unsure go to advance auto or auto zone online and enter your info and double check.Unless I am missing something maybe someone else who has a 2.8 can better answer this.No rebuild kit either unless napa has it idk.
Tuesday, October 02, 2012 8:20 PM
Ron Love Online
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=CRB21790_0065857600 OK I finally understand WHAT part you want.I could not get my freaking chiltons online working the last two days,not showing my pdf stuff when looking at pics and etc.Now I found at napa a mpfi gasket set which should have what YOU need.Check the pic and it should be to the left of the paper in the pic granted NOT exact like my diagram but has two holes,two spots for screws and should be the RIGHT item for you! This gasket is not sold separate but you could cheap out and buy some gskt paper and trace your old one and will work just fine!And you were correct fuel block(being a 4cyldr guy) it was like chinese to me but a quick learner.This should answer your ? and I have learned something out of this(thank you) after researching it for ten minutes.
Tuesday, October 02, 2012 8:30 PM
thats not the part for the 2.8. i have two fieros with the 2.8 and the fiero store has them
but there exspensive, and i have been told there very poor quality.. by the way this
is a known point of fuel leaks on the 2.8.
on the 2.8 where the fuel lines go into the fuel rail. that is the fuel block
under that is a alumunim block that has the seals built in.
http://www.fierostore.com/Product/Detail.aspx?s=60853
Wednesday, October 03, 2012 7:15 PM
If you are leaking fuel at the FPR or the return line off the fuel rail. There should be an Oring in the inside of the fuel rail. If it is missing, I replaced mine with Orings from a Universal Oring kit I bought from harbor freight for $20. It has been 2 years and no problem.
