Dont know how to exactly describe it but I need the whole piece for stock gauges. I need it yesterday. Mine isnt rolling back to zero when I turn the car off when its hot out.
Im in Georgetown, I can meet you to pick it up.
So let me get this straight, your speedometer or RPM's needle isn't going back to zero when turned off?
Year, make, model usually helps alot.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
The whole thing. Its one piece is what I'm looking to buy. It has your temp gauge, fuel, RPMs and speed.
None of them work properly.
so you want the gauge cluster for an 04 cav is what your saying
excellent, yes, I am after a "gauge cluster" for my 2004 cavalier.
Thank you.
Travis2345 wrote:so you want the gauge cluster for an 04 cav is what your saying
gauge cluster gauge set WHO CARES there shouldn't have been a conflict here obviously you can't buy 1 gauge so you have to buy the set.
if people use a different word then we normally use just think about it people its common sense
i have 1 cavalier cluster but its still in a box after i moved and i'm not 100% sure if everything works on it yet it hasn't been tested
JBO since July 30, 2001
I laughed a bit when I saw that the OP was in May and "needed it yesterday"... August bumped and still posts going into september that's unresolved.
Junk yard... 50 bucks. done... if the "cluster" is the issue.
zdoubledozen [ Matt  wrote:]I laughed a bit when I saw that the OP was in May and "needed it yesterday"... August bumped and still posts going into september that's unresolved.
I was going on a trip when I needed it. Turns out my gps has the speed on it. Also, the gauges only fault some of the time, so for about half the trip everything was good. Now that the trip is over, its not a big issue to me.
You sure its a cluster issue and not your vss?
