I’m buying a Colorado so its all for sale. I need firm buyers (cash in hand) for at least the supercharger, suspension, and wheels for this to work. So unless your making a serious offer don’t bother.
FS:
· GM Supercharger with Pulleyboys 2.7" quick change supercharger pulley, modified Vibrant WAI, NGK TR6IX (one step colder Iridium plugs), plus stock s/c plugs (only 15.000 km on setup) $2300.
· Stock sized anodized aluminum crank pulley $100
· Custom big bore throttle body $200
· Accel fuel pressure regulator and Autometer Direct tap fuel pressure gauge. $120 plus your stock rail.
· Crane Cams HI-6DI2 CD ignition system pre-wired for an LD9 $200.
· Autometer gauge pod (one double and one single mounted to A pillar), Autometer Phantom Oil Pressure gauge, Autometer Phantom Voltmeter gauge, Autometer Phantom Boost/Vac gauge. $120
Buy everthing above for $2900.
· Custom 2.5" cat-back exhaust with 18” Satin Magnaflow muffler, Magnaflow 22" resonator, Magnaflow mirror polished high flow cat, Pacesetter Header. Being sold together only (has relocated flange so it doesn’t bolt up to stock) and I would require entire stock exhaust off another LD9. $350
· B+G Springs with Koni Reds $450
· Ractive front strut tower brace $40
· 18" ADR Sokudo 10's with Kuhmo 711 P225/40ZR18 (one rim has very minor scuff, 2 tires have 50% left other 2 have 70
$900.
· B+M short shifter $100 plus your stock shifter
As of right now none of my audio is for sale so don’t ask. You can also buy the whole car for $10,000 safetied and e-tested, it’s a 2002 Pontiac Sunfire GT Blue with 96.000 km.
Eugene
spddmon@hotmail.com
