Fbod383 wrote
First step is to remove all the usual stuff in order to take off the head. Next step once the head is removed and all the old gasket material removed from the block, make sure the oil check ball is clear of debris (this will affect startup wear it MUST be clean) For ease of installation you will need the intake cam tower in order for the P/S pump to bolt up, and for the Cam Position Sensor. NOTE: although this is a 2.3 head, you cannot run HO camshafts with out a stand-alone ECM. Next comes the Head gasket.. you MUST use a gasket from a 2.3 or the smaller bore ring from the 2.4 gasket will create a hot spot for detonation. Now comes the hard part. You will need a drill and some Good High Temp RTV.. the orange stuff. The outer water jackets don�t line up perfectly, not do they need too. But just take the drill and open up the hole in the 2.3 head enough to allow water to flow through.. I usually open enough to stick a pinky finger through, you will see what I am talking about when you compare the two heads. Now, around these water passages you will need to use the RTV sealant.. use it around ALL of the water passages, even if no drilling was required (the end with the casting # doesn�t) Then reinstall the new head torque to 2.4 Specs using new 2.4 head bolts or ARP studs. Everything else will bolt back on.. at this point you can also do the secret cam swap while your at it, I would recommend using the Quad4s valve springs on the exhaust side, and HO intake and exhaust manifolds. We have seen from a stock 2.4 from 127-135hp to the wheels, after the stock 086 head (we weren�t sure how a ported head would affect the ECU), secret cam swap, and HO manifolds with 2.25� exhaust power jumped to 158-161hp which translates to roughly 195hp.. But this does require the ECU to be reflashed.
I don't know exactly how to post pictures on J-body.org, so I'll just send them to you here.
I don't know how the cometic gasket compares to either gasket, as far as the bore size (I know performance wise: it is better than both). You showed a picture of them side by side, but the only differences I could tell between them were the water passages.
The easiest way I found to drill and dremel new water passages, was by using both the head gasket and using my stock "779" head to check which holes would need to be drilled or bored out. I used your picture and circled in blue where you hadn't already circled in red, where I bored out.
As you can tell, the stock gasket overlays the area around the edges where the valves are. These are circled in blue. The same spots were circled on the Felpro picture and you can tell that they don't overlay.
The Felpro gasket I used was for a 2.4 Vin T w/o EGR (99+). You said you have a 97', but you are swapping to the 95' ECU, so I wouldn't think you would have to worry about running an EGR simulator.
Don't flame me for saying this, cause I'm sure you already know this, but: you say you have the HO cams. Personally, I wouldn't run those until after doing the 2.3L oil pump swap, cause they will push your redline, as well as your power band higher in the RPM range...and the stock oil pump (from what I have heard from just about everyone) drops in oil pressure somewhere in the mid 5K RPM to low 6k RPM range (I don't remember exactly and I'm too lazy to look it up).
I hope at least some of my babbling helped.
Brian
