secret cams - Performance Forum
secret cams
Tuesday, August 30, 2005 9:30 AM
does any one know what year cars do i get the intake and exhaust cams out of that are the secret cams and do i have to get the computer reflashed for them
Re: secret cams
Tuesday, August 30, 2005 1:00 PM
please search
"IF YOU PERSIST IN DOING WHAT YOU HAVE ALWAYS DONE .....
EXPECT RESULTS NO DIFFERENT FROM WHAT YOU HAVE ALREADY ACHIEVED"
Re: secret cams
Tuesday, August 30, 2005 1:09 PM
HO intake cam. 95 LO exhaust cam
Re: secret cams
Tuesday, August 30, 2005 1:18 PM
You need a 1995 intake cam only (it drive the PS pump). Most use exhaust cam from a LO 2.3L engine. I have some specs here.
1995 intake cam specs
200 degrees @ .050" with .360" lift
LD2 (1990+) exhaust cam specs
200 degrees @ .050" with .375" lift
Stock 2.4 LD9 Cam Specs
198 degrees @ .050" with .354" lift for the intake
187 degrees @ .050" with .346" lift for the exhaust
Stock 2.3 1995 Cam Specs
**200 degrees @ .050" with .360" lift for the intake**
200 degrees @ .050" with .360" lift for the exhaust
Stock 2.3 LD2 (1990) Cam Specs
200 degrees @ .050" with .375" lift for the intake
**200 degrees @ .050" with .375" lift for the exhaust**
As you can see the exhaust cam from a 1995 2.3L is nearly the same as the LO 2.3L
except for the lift, the '95 have 0.015'' less than the LO.
The 1995 exhaust cam have the same specs as the intake, so you can match them with no probleme and those cams are a way better than the LD9 2.4L.
I think you can use them with your stock computer with no problem.
Go to NY J-Body for more infos on secret cams swap.
If you want 1995 cams, I have it.
Re: secret cams
Tuesday, August 30, 2005 1:25 PM
^^^^ What he said. Except one thing he can not use the LO intake cam one reason 95 plus has a lobe on it for the cam sensor 95 up had a cam sensor. If you use any cam before 95 on the intake you will have to use have a cam lob for the sensor machined on.
Spotabee Racing wrote:HO intake cam. 95 LO exhaust cam
*WTF *WTF
all the time
Re: secret cams
Tuesday, August 30, 2005 6:23 PM
now they cams come out of a 2.3 and there in berrttas right
Re: secret cams
Tuesday, August 30, 2005 6:41 PM
and do i need a reflash or not
Re: secret cams
Tuesday, August 30, 2005 7:12 PM
no reflash, might consider changing your timing chain tensioner and water pump while your in there if you havent already done so. You'll definetly enjoy the extra pull with the cams.
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
Re: secret cams
Wednesday, August 31, 2005 7:27 PM
Whats this about the cam carriers, are they needed two, or just the two cam sticks?
Re: secret cams
Wednesday, August 31, 2005 8:28 PM
just the cams themselves are needed no carriers unless you want to use the HO exhaust cam then you need the HO carrier and lifters but you dont need anything but the "sticks" as you called them lol.
Re: secret cams
Wednesday, August 31, 2005 9:15 PM
Gotcha, thanks! Now, to find a set at a decent price, and to install them without my warranty company knowing... Arent other breathing mods recommended first, ie I/H/E and maybe a TB, or do they work well on a stock setup minus the Bong?
Re: secret cams
Thursday, September 01, 2005 6:31 AM
You wont feel the true gain from the cams until you do the exhaust/header and intake, but still you'll notice the difference im sure.
Re: secret cams
Thursday, September 01, 2005 9:27 AM
Ender_Wiggin wrote:Gotcha, thanks! Now, to find a set at a decent price, and to install them without my warranty company knowing... Arent other breathing mods recommended first, ie I/H/E and maybe a TB, or do they work well on a stock setup minus the Bong?
Removing the bong won't do you any good with the secret cams setup. You need to lose some exhaust restriction and increase the intake velocity. You won't beed a larger TB for a while.
Re: secret cams
Thursday, September 01, 2005 6:54 PM
Gotcha, thanks!
Re: secret cams
Tuesday, September 20, 2005 4:58 AM
im curious how much better would these cams be? would it be worth the extra money?
im sure you can buy cams pretty cheap at a junkyard anyone know?
$1050.00 + $100.00 core charge not sure if thats US or canadain
RSM Performance Cams
15-18 HP increase, 410 lift and 220 duration.
Cam carrier core charge applies, uses stock
filters.
http://www.rsmracing.com/
Re: secret cams
Tuesday, September 20, 2005 6:06 AM
If you ask me, 15-18 HP is not nearly enough to justify almost $1200.00
Re: secret cams
Tuesday, September 20, 2005 12:28 PM
that is US. I think you are better of with the secret cam swap.
all the time
Re: secret cams
Wednesday, September 21, 2005 6:37 AM
Actually, you need the Cam, Lifters & Tower from 1990 Pontiac Grand Am 2.3D Motor.
& the Intake Cam & Lifters from 1995 Pontiac Grand Am 2.3D Motor
If you don't use the correct corresponding lifters, you won't get significant gains,
& furthermore they might bind. The lifters from a 2.4 exhaust cam housing are
much smaller than the ones in the 2.3 you are taking it out of. YOU MUST
MATCH THE LIFTERS WITH THE CAM. I cannot stress this enough. So what you
need to do it use the WHOLE Exhaust cam housing with the cam & lifters in it
from the 2.3. It will bolt right on. The only thing you may have to do is plug is an oil
pressure sensor hole. I used a brass threaded plug.
"Your Premier Source For Automotive Neon & Accessories!"
Re: secret cams
Wednesday, September 21, 2005 6:42 AM
*Exhaust Cam, Lifters & Tower from 1990 2.3D Motor
*Intake Cam & Lifters from 1995 2.3D Motor
Re: secret cams
Wednesday, September 21, 2005 2:15 PM
^^ Are yuou sure.....Cause no where else have I read that. Only that the 2.3 has like 2mm bigger lifters and that the 2.4 lifters would work just fine unless you were using the HO cams which require the whole tower.... I am 99% positive that others have had perfect success with using 2.4 lifters and towers.
Re: secret cams
Wednesday, September 21, 2005 4:15 PM
Well, I"m using a mis matched profile in my ride right now.
.375 lift intake cam, 33mm lifters and tower
.375 lift exhaust cam, 35mm lifters and tower
No problems.
-M
Re: secret cams
Friday, September 23, 2005 2:17 AM
Never head anything about the lifters. My secret cams may be going in this weekend
wish me luck
Re: secret cams
Tuesday, October 04, 2005 11:47 AM
EnviouZ wrote:^^ Are yuou sure.....Cause no where else have I read that. Only that the 2.3 has like 2mm bigger lifters and that the 2.4 lifters would work just fine unless you were using the HO cams which require the whole tower.... I am 99% positive that others have had perfect success with using 2.4 lifters and towers.
I was told this by NUMEROUS people before doing both my swaps.
& especially one person in peticular that has built several Quad 4's
Re: secret cams
Tuesday, October 04, 2005 2:16 PM
The secret cams do not require the carriers and lifters..............I have done 2 sets and no one I know has ever used the carriers, the only way you need the carriers and lifters is if you want to use HO cams but it is not necessary for the regular 2.3 cam secret cam swap.
Re: secret cams
Tuesday, October 04, 2005 2:30 PM
Grug or anyone else have this 95 intake cam.... i'm rebuilding a 96 2.4 motor to go in place of my much beaten 98 2.4. and i would really like to do this cam swap while i have everything apart. if anyone has one please email me....
thanks
Jason
QwikCav24@aol.com
