Okay does anybody make a O2 sim for the ecotec? RK has on in there book but from what i heard it don't work. Tryed one off of my buddies Z24 and it did nothing. My car will be out here in about a week and i need to get this ASAP. thanks all who can help
If your interested in custom aluminum tilt wheel levers hit me up!
listening as well...my post cat 02 hates the 110 i run occasionally at the track when i crank the boost
5K PB: 24:50
10K PB: 54:26
rk sport has them they are no different than the other engines about 60 bucks if i remember
there is nothign out for it, me and Cheesecake both tried geting some copanies to make something, the companies eitherflat out said no or it didn't work when tested on CHeesecake's cat-less 04 eco.
The JBP reflash can delete the entir circuit form the computer so seeing nothign wont cause a light but thats not exactly a cheap option, i think gits $500ish
Like i said the RK on don't work. Cause my buddy with the Z24 has the rk one and i tried it with no luck.
I was talking to a buddy with a SR20 240 and he said that he has heard of people not even putting the second O2 into the hole. Just wiring it up outside the exhaust. By doing that the computer sees fresh(er) air causing it not to get the low catalyst eff. light and throwing the comp into limp mode. I might try it when i get the car back out just to see if it works.
Do you guys thinks this might be a temp. solution?
well if the downstream o2 throws a code it WILL NOT go into limp in mode. its just there to monitor the catalyst...nothing more. i know because ive been running with high and low codes for it for about 2 weeks now and i ran my best time ever on the track with it on
. just makes it so theres no CEL
5K PB: 24:50
10K PB: 54:26
yeah but that cel is annoying as $hit and if something else is going bad i would like to know that it is not a low eff. light. But yeah i have been running 2 years with the light on
i tried the sim from an 02 camaro and just spliced the 02 sim onto the plug for my car. worked for about a week and the cel came back on i reset my car from the batt a couple of times and it just kept coming back. finally gave up and put a high flow with a cut out. by the way I'm not boosted. don;t know if any of that helped but thats what I'm here for.........................useless information.
If it's too loud, you're too old!!
Actually, there is an o2 simulator that will work on the ECOTEC.
Contact
this guy
he makes them--and cheap. they splice into the o2 sensor wires. I'm sure he can tell you more about them
^^^ Yep, got one of these for mine. $21 shipped. Looks like a little pipe bomb, you'll see what I mean.
You have to have the 02sensor in the path of the exhaust, then splice this inline with the wires coming from the sensor. I run 3inch all the way with no cat, so I'm just gonna weld in a bung and put the sensor around where it should be.
I'll let you know how it works out, when my car is back on the road.
Contact him on AIM swtcav99, he's usually always on.
