Well, i have started to remove some of the mods i wont be needing any longer and the Apexi SAFC-2 is on eof them, i ony really used it a couple of times, mostly used it for a tach before i swapped guage clusters. I bought it about a year and a half ago, got it off ebay for around 275 and i believe i still have all the manuals for it and yes it is the english US version and Black also.
Only has a few very minir scratches, and other than that its perfect.
Im will to let if go for 150 bucks, give me a shout if your interested.
Mike
1992 GMC Sonoma GT #492. Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5. Mods and pics are in my registry.
That pretty much says it all.
Support the site that supports your habit, Go Premium.
hey did you have it hooked up to all the way or just partialy. I have one and I have fininshed hooking it up. I just need to tie in the fuel controler part. Which wires did you use to split in.
Ecoclean wrote:hey did you have it hooked up to all the way or just partialy. I have one and I have fininshed hooking it up. I just need to tie in the fuel controler part. Which wires did you use to split in.
No it was fully hooked up, i just hooked it up the the TPS, Knock, MAP, RPM Signal power and the dual ground wires, it increases fuel theu the MAP sensor, it takes the MAP sensor reading from the engine and if you want more ar less fuel it modifyes the signal and then send s it to the PCM.
Mike
the wires that were used in the map sensor where what color?
The wires on the SAFC-2 harness?
I believe they were green and yellow.
Mike
yellow going closer to the ecu
u still got it.. i might buy it.. can u help me install it... wires own me!
here comes the boost!
hey man.. just give me a call 832 455 5879
teamjenzo wrote:u still got it.. i might buy it.. can u help me install it... wires own me!
Yeah i still have and yeah i cn help on the install, thats not a problem.
Ill give you a call this evening sometime.
Mike
sorry i havent called u back.. lost the number.. i still want it and im about to put the money in paypal.. ill call u later and we can discuss pick up... probably sometime next week
hey man.. i was about to order a safc and then i remember i bought urs hhahaha give me a call so i can come pick it up tomorrow
Yeah thast cool, i ws wondering if you had forgot about it.
Give me a call before you come over. 281-687-4168
Mike
