um... I'm still pretty new to california...
but I have a question for all you so pac guys.
Where the hell can a guy fill up with higher than 91 octane?
I ask because I'm on my way to doing a 2.3 head swap on my 2.4 and I'd just like to make sure where I can get some higher octane gas to control some of the knocking/detonation from he amount of compression that will probably be run... 11.5:1 or so?
Anyways could someone point me in the right direction?
If you don't mind taking a long drive to get it you can come up here to sac. We have 100 at the pump at a local station.
Might want to bring a couple barrels with you since you will porbably need to refill a few times on the way back.
santa fe springs. when i get home from work today ill sne dyou the info. they have fuel up to 120 octane.
2004 Cavalier, 2.2L Ecotec
1965 El Camino, 396 BBC, 14:1, 800 BHP
titus03 wrote:If you don't mind taking a long drive to get it you can come up here to sac. We have 100 at the pump at a local station.
i also know a gas station in penryn (10min from sac) that sells it in cans. im not sure what size cans they are. ill be able to see on wed. for you. but you can purchase a ton of it and throw it in your back seat or trunk. they look to be about 3 gal. cans. ill know for sure on wed. good luck till then.
-Www.IznTrbl.Com-
I thought you were going gm charger.
Eh just mulling over ideas an options right now. the head idea was actually prompted by a long discussion I had with a friend of mine on quad4forums
I really should have worded my first post differently, but eh, I'll just probably scrap this idea. it's already becoming overly complicated.
Thanks either way guys.
I think I'll just stick with the m45.
buy octane boosters lots and lots..lol or glamis
