It could be the wiring to the pump too. Or the fuse.
check fuse
check wiring, you can get a tester for less than 10 bucks at the hardware store to see if the pump is recieving any current
if the fuse is good, and the pump is getting current, replace it.
You should be able to do it yourself.
-Chris
No your not done testing. Does it have ground, after all ground is half the circuit. It could be a loose ground wire.
not to thread jack but i have a problem with my right windshield wiper when it squirts fluid it. it only squirts a little out. the same thing happened to my last j-body as well. anyone know whats wrong?
<img src="http://registry.gmenthusiast.com/images/jiggaman/personal_pic.jpg">
