Been having a loud as hell rattling clunking sound in the rear over every little dip and bump, changed out the rear strut mounts with kybs and its still there just as loud. struts arent leaking, kinda thinking trailing arm bushings but am told to try struts first... opinions?
you have a rear sway bar?
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
Also check your shock lower bushing. And retorque everything. Good luck and let us know what you find.
NCR-SCCA
no rear swaybar, noise is also coming from front when cold. all new bushings and links in front. thinking cartridges in struts are gone and rattling around... shock bushings are ok.
Do you have thrust bearings so your springs are free to rotate when they compress?
