2 weeks ago i went from having one low beam to no low beams and i changed the combination switch and i also changed the drl relay, and the headlights. i have high beams all day but no low beams.
is there something i should check for before i assume its the wiring
I have the same problem but i still have one low beam? one fog light works, no power to the other one. right side works left side doesnt. DRL both work same with high beems.
i don't have fog lights but my drls blink wen i put it in to drive
2002 chevy cavalier ln2 87000 miles
I am having a similar problem. My low beams don't work at all. When I turn low beams on, all that works is my DRLs, which is better than no lights at all. My highs work fine. Could replacing the bulbs fix this?
Philippians 3:10 (Amplified Bible)
10[For my determined purpose is] that I may know Him [that I may progressively become more deeply and intimately acquainted with Him, perceiving and recognizing and understanding the wonders of His Person more strongly and more clearly], and that I may in that same way come to know the power outflowing from His resurrection [[a]which it exerts over believers], and that I may so share His sufferings as to be continually transformed [in spirit into His likeness even] to His death, [in the hope]
my headlights were all messed up and it was the wiring right under the battery box but mine was a 04
switch most likely, i just had to replace mine.
It does appear that the switch is the problem.
