I came across a post a while back about how to remove the amber bulb and reflector inside the corner light.
I cant seem to find it anywhere.
Any help?
13.520 @ 98mph! 220whp 234tq
when i did mine i just heated up the seals with a blow drier and used a screw driver to pop the covers off. (Took along time not to chip) Then stuck the screw driver in the light hole and hit it to pop off the bulb cover. I left the reflector in mine but you can just pull them strait out! then just reseal with clear silicone and your done!
hmm there was a post on here that someone didn't have to take the lens off they broke it off in there I guess.
its under the library IIRC
www.driftnamiperformance.com
What the hell does IIRC mean?
IIRC = If I remember/recall correctly.
Ok cool thanks.
