I swapped my front end from 97 fire to 97 cav but i had to wire in 194 sockets for turn signals, they work but they blink fast like a bulb going out.
The bulbs are brand new, is there something else im supposed to change? like the flasher or something?
im guessing you didn't leave the 3057/3157 plugs on from the sunfire harness... the 95-99 cavalier uses two turn signal bulbs on each side, a 3057 in the bumper and 194 in the corner light. the 194 doesn't draw enough current so it reads it as the 3157 bulb is out in the front(technically it is)
ok so instead of cutting off the 3057/3157 i should have just spliced into it for the 194 that i needed. Ill be wiring it back up asap
thanks a ton
should have just swapped over the headlight harness over
when you get done with this swap bring it up to oriellys i would like to see the finished product
