Ok, my 03 sunfire has a big dent in the trunk and im wonder if there are any other years i can get a trunk from.
You can use any 95-05 Sunfire coupe trunklid, but you'll have to swap on the 03-05 trunk filler panel.
Actually all 95-05 Sunfire Coupe trunks will fit, need to read my links more carefully lol
Cruisin4DrCav wrote:Actually all 95-05 Sunfire Coupe trunks will fit, need to read my links more carefully lol
Apparently you're the one needing to read more carefully.  You're the one trying to tell him he needs a whole rear end swap to use a 95-02 trunk lid when all he wants to do is replace his dented trunk.
95-05 Sunfire coupe trunk lids are all the same.  The only difference is the trunk filler panels which can be swapped around easily.  If you look on the underside of the trunk lid you'll see the nuts holding the panel on.  The 03-05 panel will swap right over to the older trunk lids.
Micah (Shadowfire) wrote:Cruisin4DrCav wrote:Actually all 95-05 Sunfire Coupe trunks will fit, need to read my links more carefully lol
Yep just trying to correct myself, we posted at the same time
I apologize then.  I thought you were trying to correct me lol.
No prob, as long as the OP got the answer he needed lol
thanks guys. cause there are a ton of 95-99 sunfires in junk yards around me.
