i have a 02 sunfire sedan and did a cavy trunk swap, all seems well but the trunk has about a quarter inch gap all around and sticks out from the car. it doesnt seem flush at all. what can i do?
adjust adjust adjust
It will fit perfect you just gotta take your time with it.
Satch Timeline Progress Thread
JGM T-SHIRTS!!!!
In Loving Memory of Phil Martin December 14 2005
Alexis: Dustin, you're ghey, lol. I am better. I have tits, and tits rule all.
what do i do to adjust it is what im asking
Loosen the mounting bolts.
use the rubber bumps on the underside and the bolts you used to mount it. also i believe you can get some adjustment out of the mounts. but you would most likley have to take out the rear deck to get to those.
what do you mean by adjust with the bolts, if i loosen them wont it rattle all the time?
Wow.....
Loosen the bolts, move the trunk lid, tighten the bolts, and repeat until it's perfect. If you still dont know how to do it, take to someone who can.
Close the trunk. Go inside the car and loosen the bolts. Have a friend help move the lid around until its flush. tighten bolts while still closed.
whiskerbiscuit wrote:Close the trunk. Go inside the car and loosen the bolts. Have a friend help move the lid around until its flush. tighten bolts while still closed.
Good idea right here. I have to do this, my trunk looks a bit off.
