What is the differences between the 2 door and 4 door import fighter sides if there are any at all? I am looking into a set from a member on here and am curious.
Thanks
Larry.
2009 Ford Mustang V6
Im not positive but I would guess that the 4 door ones would be too long for your car.....
i was always told they are the same. skirts will fit both coupe and sedan
only difference i could think of is the mounting under the doors.
They are the same size..
Only difference- The sedan skirts have that lip that runs along the top of the skirt all the way down, through both doors.
The coupe skirts only have this lip until it reaches the end of the door, then it goes flat so it can mount against the panel..
So coupe skirts will fit on a sedan, but the flat part might be visible- But if you wanna put sedan skirts on a coupe- You'll have to cut the last 2-3 ft. of the lip off.
Would it be noticable from the outside of the car or not really? I am kinda scared to cut the sideskirts.
Larry I told you the difference you crazy photo poster
get at me in aim ill see if i got any pics to show ya
The01Cav wrote:Would it be noticable from the outside of the car or not really? I am kinda scared to cut the sideskirts.
if you are trying to put the sedan skirts on a coupe, youll have to trim it.  otherwise that inch or so lip would push the skirts out behind the door to the rear wheel well.  just take a dremel to it....5 minute job since you arent customizing it, just trimming int
coming back in 2008...
I was really hoping to come across some pics of 4 door skirts mounted on a 2 door to see how it's trimmed and what it looks like. I'll just wait for MantaZ to show me his side skirt.
