Hey, I am about to swap for some Toyo tails, but I am told they do not ocme with the wiring harness, now what will this mean ? Can I still hook up my brake lights ? I guess I wont have the amber turn signals ? Will they still work ? I need some clarification
Thanks !
My Cav
I give up...
You will need the harness in order to wire things up correctly...and then it just a matter of splicing wires.  As far "not" using the amber turn signals, you could try to use the stock harnesses, but I don't know if the connector is the same size. I would have to look later.  But doesn't that kind of defeat the point of having toyos, by not using the amber section of the tail light.  Here is simple diagram that I used for wiring my toyo's
Driver Side:
Wires from Toyo Tails: From Car:
Brown-------------------------------------------------------Brown
Blue----------------------------------------------------------Yellow
Black---------------------------------------------------------Black
White-------------------------------------------------------Tap into 3rd brake light
Passenger Side:
Brown--------------------------------------------------------Brown
Blue----------------------------------------------------------Green
Black--------------------------------------------------------Black
White--------------------------------------------------------Tap into 3rd brake light
Thanks for the response, I am getting further information from the seller
My Cav
I give up...
As long as it comes with the bulbs for it your fine. Even if it only has the signal bulbs you can use them and retain your stock harness just have to swap a couple wires around.
2009 Ford Mustang V6
ahh, good to know
My Cav
I give up...
