Having a problem hooking the wires up for some reason. I followed the instructions on wiring up the switch and when i hit the Driver side left and right mirror buttons the mirror would move up and down instead of left to right. And when i hit the up and down buttons nothing would happen. The Passenger side does the same thing. Also none of the wires I have match up with the relay from the mirror to the relay since i dont have stock power mirrors i had to run the wires. But for the most part i tried to run the same colors from the mirrors themselves into the car. I check the voltage and its giving me some messed up readings, . Could the problem also be i have another peice that came with the mirrors I have 1. switch, 1. 11 wire relay, and a relay with 4 wires coming out of it. So if anyone could help me it would be great
(I posted this in the toyo mirror topic to no response)
---Under Construction again---
you dont need the 4 wire relay, i received one as well, and never used it. the wires will not match up on the relay and the switch,
try these connections, i tried the first ones posted up and had no luck, weather i am just stupid or what i donno, but then i found these and they worked like a charm, had full power mirrors in 2 hours. but i was soldering everything to, so shouldnt take you as long otherwise
left mirror.
connector no connector
relay wires
pink/black---------green
red/black----------yellow
brown/black------brown
white/black-------blue
mirror wires
yellow------white
white -------red
green-------black
right mirror
relay wires
blue/black--------green
orange/black-----blue
green/black------brown
grey/black--------yellow
mirror wires
red/white---------red
blue/white--------black
brown/white--------white
<br>
When you put mirror wires those are the wires that connect to the switch right? and if so where are you gettin blue white from?
whats goin on man, i just got your email, and i figure i will post it up here so if anyone else is wondering the same thing i can help them out at the same time.....
ok, you should have 3 wires going to the switch from each mirror and then 4 wires going to the relay from each mirror. ignore the connector/no connector part, i just copied and pasted them from
this post and to give credit were it is due, they are TRD 901-Z™'s directions.
but in any case. connect the 3 wires from each mirror to the switch via the color codes above, and do the same with the relay. very simple i thougt, but if you have any more questions feel free to hit me up on aim, its the best way to get up with me. makeitmikes04. ight boss. have a good one
Well my car was just broken into last nite so i dont know if im going to even bother with the install nemore. But just incase the problem im having is the blue/white wire on the switch... On my switch i dont have a blue and white wire but i do have a black and white wire.. Should i connect it to that but isnt that the wire for the mirror to fold and unfold?
