Ok maybe some one can help me out! I am testing out paints for my car and have 4 different once here. All of them at a DBU paint that i have to mix myself at my auto parts store. That is the easy part. What i dont know yet (and boss is gone for a month) is what kind of reducer and hardener i need.  How much paint to how much reducer and how much paint to how much hardener do i need?
If ANY ONE can help me by monday it would be great. i want to spray a little with a friends air gun. If you guys need more info i have it all right here in frount of me.
normally the can will say what to use.. usally will say hardener with a #.. which is the part number.. If not ur paint supplier wil lbe able to look it up for you.
this is all me mixing paint from all sorts of otehr paints. its not a basic blck, red, yellow, etc... its called gunmetal poly ... it has metallic flake added, pearls, and like 5 other colors ... the formula sheet doesn't say as to what stuff to use. ill jst have to wait until i can talk to my boss.
any paint will have a recommended hardener and reducer needed..  is it paint u custom mixed and made a name for? if all the paints were same type and same brand, all u have to do is use the recommended hardener and reducer that, that brand says..
yeah i got him the #'s he needed..it was a ppg deltron dbu paint
sorry i couldnt help u more kyle..
some paints dont need a hardner some you just reduce 1 to 1 or 2 to 1 some paints if you need a activator/hardner i know with nason from dupont its 2 parts paint to one part reducer to one part hardner
if your saying you have the dbu system  that is ppg
  dbu is a old technology  like over 10 yr old  material,    but still a decent product
   i highly recomond using ppg`s dbc system,  i will get to that later in this response
 ok so the dbu system used the dp sealer  and it used    250 primer,    the clear it really didnt matter
   but you can use the new ncs sealer  and the ncp primer and the dcu 2042 and 2021 clear,  not a problem,   but the dbu system is very thin and the mettalic is not as haevy as the dbc system,       so a basic red in the dbu will take more coat to cover then the dbc system usally take 2 to 3
          so the ratio on it is 1 to 1 1/2 drr reducer,   DRR=reactive reducer   it acts as a hardner
     now on to the dbc system   the pgment is allot thicker the mettalic is thicker and  matches the OEM mettalics allot better,   still uses the powder pearls,      so this system  is allot faster,  more productive,  and easier to use
     the base ocat does not need to be flexed  dbu system did,    the primer filler is corrosion resistant,   ole skool primer is not,      the sealer  lays out flat no shine and smooth compared to the dp sealer,    you can still use the dp sealer it will not hurt but ppg does not recomond using it with the dbu system
          ok so anyway....... it also uses the DT reducer for the whole refinishing process,  hence why it is easier to use
   so the ratio for dbc is base coat=1;1,  now since this system uses the dt reducer it is a non activated base coat now there is a product called dx57 which makes it a activated base coat aids in laying down heavy pearls and mettalics also aids when you do graphics,    and PPG says it is chip resistant,   the  front of my car has only 3 chips in it    just to give ya a example    the ratio for that is 1;1 to 5% dx 57
                the clear is 2042 or 2021 i recomond using for the best gloss and durabilty
   i will finish with that any more questions just ask
can i haz bondo
