im lookin to see if any one has the brake light section wiring harness/plug for the toyota cavalier taillights... i jus got sum and the only came with the turn signal harnesses... so if any 1 has them and could help me out, drop me a message, of if you know were i could get em... the harnesses have 4 wires instead of 3... (black, brown, blue/green, and white)
THANX!
KrIsToY!
Myspace
have you searched? i know instructions have been posted how to wire them up.
That they have, cannon.... there's 3 other toyo tail threads on the front page alone....
Kris, if you have any specific questions, please shoot me a PM. I'll see what I can do about answering them for you.
yea the wiring instructions are actually very good except the bake light harness on the toyo tail has 4 wire, and when i got my tail the didnt have em and i need to figure out how to make em work with the stock 3 wire harness...
Myspace
as far as i know u need the pig tails.....
Team GREEN
kris wainwright wrote:yea the wiring instructions are actually very good except the bake light harness on the toyo tail has 4 wire, and when i got my tail the didnt have em and i need to figure out how to make em work with the stock 3 wire harness...
LoL that is just so funny! Hmmm black goes to black, brown to brown, and white wire is the white you run from the 3rd brake light you tap into. ( 3rd brake lights wires are black or white, you need to tap the white). and the blue or green wire on each side go to the other wire there that is not the black, brown, or white.
How is that hard? Make sure to cut the wire up on top of the colum.
the extra wire for the brake lights comes from your 3rd brake light
and you gotta take a wire out at the steering column
dam rookies that cant read instructions very well
the reason it is so hard is because in all the instructions, people have the 4 wire harness that comes with the toyo tails... when i got my toyo tails, i didnt come with that 4 wire harness for the brake light part of the tails... the stock and toyo harnesses both have the same 3, black, brown, and green/blue wires but the toyos have the extra 4th, white, wire that is part of it so that you can have working seperate signals... thats my delema... im not sure how to rewire a stock 3 wire harness to work for the toyos... there are no instructions anywere that i could find to explain how to make em work with the stock 3 wire... they all say that you need the toyo harness for it to work...
KrIsToY!
Myspace
