OK, I have a good size dent in my front bumper on the driver's side. Can somebody tell me how to get it out, with out chipping paint.
2004 Ecotec Cavalier 9.9 in the 1/8th mile. 15.7 in the 1/4 mile.
I beleive a with some heat(heat gun, blow dryer kinda thing) and pressure u can push it back out.. im not 100% sure tho.
Pull the bumper cover off heat it up and push it back out from the inside.
its just plastic, you should be able to just push it out
DEFINITELY wet it down with some water, and then get a plunger, and plunge it out... WORKS LIKE A CHAMP... The suction of the plunger will suck to the bumper, and when you try and pull it off, it will come right out... hope it works! I know it did for me!
i believe the plastic is either tpo or tpe not easy to work with , but the heat gun heating from both sides the dent will work back
but don`t get it to hot for the plastic will wrap yes plastic does wrap due to the heat to much heat i should say
it will have to be repaired once the dent is out but that will work for the tiem being
can i haz bondo
