I noticed a few weeks ago that everytime I started my car, my DRL light would flash and a clicking noise would come from the relay. I checked the lights, and I have a high beam out on the passenger side. I replaced the bulb, but it turned out the bulb was fine. I traced the wiring as far as I could, and couldn't find a break anywhere. I am going to take the volt meter and check the wire next. If I have no voltage at the bulb, what do I look for next??
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
im having the same prob, exept my drivers side low is out
JUST ur luck, ive seen about a hundred of the cavs n sunfires with that problem, on many there is a common ground under the battery tray, or right behind the washer fluid jug, yes it a pain in the ass taking it out...also sometimes there is a relay under the hood latch area sometimes, usually the 96 an older had that problem...most likely, ur problems around the washer jug...FORGET ABOUT THE VOLTMETER....trace each wire, give them a stretch make sure that the wire doesnt pull apart, if it does its probs the one ur looking for but check them all....if u have any Q's just ask...i know those cars like the back of my hand...have fun
